Clears all PIM snooping neighbors, joins received on the VLAN, and the VLAN forwarding entries.
| name | Specifies the VLAN to which this command applies. |
N/A.
None.
The following command clears the PIM snooping database for the Default VLAN:
clear pim snooping "Default"
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM snooping feature, see the Switch Engine v33.1.1 Licensing Guide document.
